Old 09-22-2002, 02:31 AM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
Using OEM bullet controllers with TOMY cars...possible???..take a look.......
Well i've noticed that some people have wondered if its possible to use an oem Bullet controller with the TOMY bit char-g. Some peopl said it can be done, but you have to resolder the two small copper wires......i was thinking......what if you just took out the steering magnet and flipped it around??? I figured this might work, because i accidently put a TOMY steering bar in a bullet and the bullet had reverse steering while using the bullet controller. So if anyone has a Bullet and a TOMY with the same frequency try it out..maybe it could work.....
Old 09-25-2002, 11:01 AM
tinyrc's Avatar
tinyrc tinyrc is offline
Good idea! However, on the bullets that I have seen, the throttle is also reversed.
OEM bullet motor Impreza WR reX Bit Char-G Mods and Projects 6 12-25-2002 03:05 PM
Bullet type controller to run Tomy Bit? verbalkint Bit Char-G Mods and Projects 0 09-11-2002 10:27 PM
Can u use Tomy NiCDs in OEM Bullets? Mellow Yellow Bit Char-G / MicroSizers 3 08-30-2002 03:26 PM
Will TOMY SUPRA BODY fit my OEM Bullet??? SPEED Bit Char-G Parts and Hop-Ups 4 08-23-2002 11:32 PM
