Old 08-06-2003, 07:38 AM
boho's Avatar
boho boho is offline
Camera springs
Clone controller question
Alright, I just replied in another post about using clone controllers, and it raised a question in my head.
I'd much prefer to use a $10 clone for it's controller's range then swap a PCB for better range. Witch makes me ask if everyone knows about witch clones have compatable freqs.
I would like to know if anyone has found other compatable clone controllers that will work with BCGs. Witch ones have good range, and list them if there's alot please.
And lastly, is PCB swaping still better for some? I already know it will offer more freqs in the same band. besides that?
I found a clone called cyclona that has 3 of the freqs that tomy uses.
When I say compatable, I mean you can actually run the BCGs with NO problems.
Old 08-06-2003, 09:35 AM
Got 4.2 King? I do : )
i know shen qi wei's are fully compatable
i have a 27mhz ms and a 27mhz shen and i just use the shen controler for both cars since the range is over twice as much
also i changed my brothers 49mhz to a 45mhz to work on a shen controler
i've seen shens in 27mhz, 35mhz, 45mhz, 57mhz i think all those are also bit frequencys
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Controller question Demon666 Bit Char-G / MicroSizers 2 02-15-2003 09:43 PM
Clone question?? Jeremy386 Bit Char-G / MicroSizers 1 11-22-2002 02:49 PM
4 channel controller in question Blue Bit Bit Char-G / MicroSizers 0 11-11-2002 05:56 AM
