Old 07-30-2003, 06:54 PM
Got 4.2 King? I do : )
49mhz
ok this is sorta weird. all my cars are 27mhz and my brothers has a 49mhz, and a clone (45mhz). now all my cars work fine, but the microsizer 49mhz wont get a signal. the only time it works is when its on the controler and the intenna is close to the car, and it doesnt even work like that. but the 45 controler can control it if its touching our close (about 1 cm). i took the car to hobby town and the controler they had worked on the car. i told microsizers this and they sent a new controler. i tried to get it working again and still no luck. i told microsizers it still didnt work and they sent a new car. but still the new car and transmitter dont work with any of the 49mhz cars or transmitters. lately i tried moving the car with one on the controler and the other one was charging. they would both work once in a while and this only happend when the old car was on the transmitter.
i'm totally confused with the cars and was wondering if someone has an idea with whats wrong with them. the only thing i can think of is a 49mhz signal is going threw my house and stoping the car from responding other than that i'm stumped, help would be greatly appreciated
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 07-30-2003, 07:36 PM
MicroSpeed's Avatar
was the 45mhz frequency active while running it? sometime close frequencys can cause interference (45-49). Other than that I cant think of much of anything
Old 07-30-2003, 11:02 PM
SkyLiNEz 4-eva!
id say just get a new car because with MS the pcb it a direct match to the controller's frequency. so, no matter what, unless the controller is a direct match, you are screwed. sorry 2 give good people bad news.
Old 07-30-2003, 11:05 PM
I have a beach ball...
Sounds like your POTS got messed up somehow. On the top of the PCB is a little hole with a screw in it. Turn the screw until it works again.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 07-30-2003, 11:14 PM
SkyLiNEz 4-eva!
dat could be it too. or maybe he should get a new car. wait, what are POTS? never heard that b4.
Old 07-30-2003, 11:37 PM
not really i just charged the car and then i put eh remote intena close to it and it worked the other car wasnt moving, dead battery
skyline you said that with ms the controler and car are a direct match but with my car the clone controlers work with the ms and the ms controler works with the clone
murcielago, that sounds like it might be it, but i'm still looking for another screw driver small enough to fit in
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 07-30-2003, 11:58 PM
That, unfortunately, is the only problem with fixing this.
'65 Ford Mustang
All the RS goodies
Old 07-31-2003, 12:08 AM
nice i found some screw drivers that are hella small i knew i had some some where
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 07-31-2003, 12:23 AM
damn when its on the controler i got it to run but as soon as its not it dies
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 07-31-2003, 12:31 AM
that was wierd, when i had one on the controler and the intenas of the two cars touched they would go but when they disconnected nothing
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 07-31-2003, 12:33 AM
or when one car was on the chargerand the other car is close to the transmitter intenna they both work, on the last to things the cars are working in unisin if one is on the other is if one is off the others off
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 07-31-2003, 01:33 AM
2G2SILVERSTRAT 2G2SILVERSTRAT is offline
im rick james bytch
Send a message via AIM to 2G2SILVERSTRAT
you can have my 49mhz microsizer and remote for 10 bucks shipped to you with a 2.6 motor in it.if you want it even runs straight as most ms dont...
Old 07-31-2003, 04:17 AM
boho's Avatar
boho boho is offline
Camera springs
Booster cars and regular cars are on different frequencies within the same band. If you're trying to control a booster car with a regular car controller you would get those same symptoms that you explained. As far as different companie's clones and stuff, well they may be on different frequencies within the same band too. For example 49.0mhz and 49.5mhz. Is it a booster car? They make controllers to control those. That may be what the hobby shop people used.
Old 07-31-2003, 11:45 AM
none of the cars tested have been booster cars my bro and i dont have any and the one at hobby town doesnt, so i dont think thats it
and murcielago you pot thing worked sorta, i got the cars to work fully when on the charger but die when not
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 07-31-2003, 12:14 PM
Lord_Nick_D's Avatar
I cant stop modding
well that means you battery is dead
try cycling it by charging it up fully then fully dischargeing it also charge it more then once its better
WTB: 49Mhz turbo controller w/original whip jboehm Bit Char-G / MicroSizers 0 01-13-2004 03:55 PM
For Sale 49mhz Microsizers Set 2G2SILVERSTRAT For Sale/Trade 3 07-29-2003 01:09 PM
FS: 2 NIB Z-cars, black & silver, 27 & 49mhz ucfdan For Sale/Trade 0 07-15-2003 11:08 AM
WTT 49mhz MS chassis for 49mhz ZZ chassis rt450 For Sale/Trade 0 07-10-2003 01:23 AM
Are the 49mhz and the 27mhz different cars? JimBob Bit Char-G / MicroSizers 7 09-12-2002 04:49 AM
