okay, I'll try to explain it again (what I really need is pictures)
here is a piture of a wheel, the spacer is the o next to the [] and the axle is the ------. Remember, the spacer is actualy part of the wheel, it is the part that keeps the wheel from rubbing on the chassis.
[]o------
the gear and other wheel have been omitted so they dont distract you.
what you need to do is cut ~2-3 mm off the spacer so it will fit because originaly the amount of axle between the two wheels is too short. with me now? The reason it may not perform up to spec
without a booster car is because with a booster car you can press the boost button which not only makes the motor run faster but gives it more tourque as well. since the ratio is so low you need all the tourque you can get.
please post a reply if you do not understand as I will try to explain it to the best of my ability (I problably sound really confusing now).
Click Here for a better place to find instructions with pictures
one last thing, you need to use the larger WHITE 7T pinion gear when using KIT/BIT racer gears (it comes with the KIT/BIT racer motors) the black 6T pinion from MS/BCG motors WILL NOT WORK
if you have any more questions visit the link I posted or post a reply to this message.
whew,
David
