Go Back   TinyRC.com > For Sale/Trade
Old 05-04-2003, 08:27 PM
FLAMES FLAMES is offline
Gettin' out, Sellin' everything, Updated
UPDATED.
This is gonna be long. I'm gettin' out so i'm sellin' everything. I'll sell a few things single but only a few and since I dont have paypal it needs to be cash, no personal checks unless have to. I mostly worked in the ZZ area but if theirs an asterick (*) then its for MS. I spent about a total of $280 bucks for all this stuff give or take a few but im only askin' for $175-$200.
I am completely honest so I wrote down what is worng with what. Pics comin' soon.
Here goes:
Bodies:
3.00-Eclipse body cut for a T top
5.00-*Celica body
3.00-Muscle machines diecast supra body, cut to fit ZZ chassis.
3.00-H1 body from electric set fits ZZ chassis
3.00-Truck body from electric set fits ZZ chassis (dual exhaust, in order for body to look noraml you have to slant it forward. In the rear their is a big space. I have a lego wheel set-up that fills in the space.
3.00-Blue Pt cruiser (sticker decals, dual exhaust, hood mod gone wrong so I glued it on and cut the center for a blower, you can have the blower if you want).
4.00-*S200 body (holes for ZZ spoiler in the rear, started hood mod - never finished nicely done, all that is needed is to finish cutting it through).
5.00-*Lancer body (succesful hood mod, have hood, I also have a blower that fits perfectly in place if wanted).
6.00-Suntzu's escalade (wheel well cut large because the body is for a stretched ZZ chassis, it looks best if you have big tires for it).
Chassis: These have complete chassis except where noted.
15.00 each-2- 27 MHz ZZ chassis (one has 2 broken steering wires, one needs atenna resolderd and - batt connecter resolderd).
15.00-1- 27 MHz bensu chassis (got solder on pcb cover, needs L turn wirer resolderd, and - batt connector resolderd.
15.00, 10.00-2- 49 MHz ZZ chassis (one needs blue wire resolderd, needs new pcb cover, one need every wire resolderd).
Contollers:
7.00-1- 49 MHz ZZ controller (with 2 ft antenna)
4.00 each-2- 27 MHz ZZ controller
3.00-1- 27 MHz bensu controller (has hole in front for joystick controller mod)
4.00-1- 40 MHz panther controller
Batts:
3.00 each-3- 1.2v 100 mAh batts
2.00-1- unknown
3.00-1- tomy Ni-Cd, mAh unknown
3.00-1- 70 mAh Ni-Cd
5.00 closed, 3.00 open-2- 3v watch batteries (one unopened)
Tires:
1.00 each-4 complete factory tires
2.00-1 complete all season tires
2.00-1 complete sport tires
3.00-1 complete lego tires with rims
Rims:
2.00-1 gold
2.00 each-2 chrome
1.00 each-2 aluminum
3.00-1 chrome custome Muscle machines (all you have to do to fit them is grind down the hump in the center of the black wheel, the push into place, fits like a glove.
Axle:
2.00-1 green axle (lego wheels with rims super glued on it)
1.00-2 blue axles
3.00-1 red axle
3.00-1 blue (with custome wheels and rims, bigger tires, not monstorous)
Gears:
.50-3 blue
Motors:
5.00-1 red
3.00-2 green
?-1 anonymous red
2.00-1 motor works white (hard wired with wires)
Suspension:
3.00 each-2- 3 hole
2.00-1- 2 hole
1.00-1- 1 hole
.50-5- no hole
Pcb:
5.00-1- 49 mHz ZZ pcb (christmas edition).
5.00-1- 27 mHz motor works pcb
Miscellaneous:
10.00 -AC stand alone charger with ZZ charging base.
.50 each-2 steering coils.
.50 each-4 heatsinks
.50 each-2 seats (for a custome enterior)
1.50 each-3 spoilers (1 muscle machines, 2 ZZ F&F)
.50 each-4 batt connectors
3.00-1 plactic engine for ZZ (thin, but needs to be moded to fit appropriate car)
.50 each-4 knuckles
1.00-1 top for the steering front (the one that holds the suspension bar).
2.00 each-2- 2mm white led
2.00-1- 5mm red led
2.00-1- 5mm green led
1.00-1 yellow rectangle led
1.00-1 red rectangle led
10.00 each-2 ZZ track sets
10.00-1 ZZ case
3.00-1 cone & barrel set
3.00-1 led switch
5.00-1 bare chassis (nothing but the metal in the back that holds the gear and links the motor to the pcb).
4.00-1 cleaning kit (missing long screwdriver)
3.00-1 ZZ controller antenna
1 Silver porche 911 set still in box without micro rc
1 Blue civic set still in box without micro rc and 49 mHz controller.
I need a mod like mystic to edit this post and tell me what I should put for a price. I think $175 to $200 might be good. And could you tell me what you think each should cost.
FLAMES,
UPDATED
Old 05-05-2003, 12:12 AM
Aquarius's Avatar
Aquarius Aquarius is offline
MS Pro Know It All
I dont think you'll find anyone to buy the whole lot. I'm interested in the Esclade body and supra body if you could post pics
Old 05-05-2003, 01:16 PM
The supra is that but glittery forest green, wider wheel wells, no hood - unless you want, no spoiler.
http://www.diecastsonline.com/imports/97supragrape.jpg
Old 05-05-2003, 06:19 PM
Aquarius's Avatar
MS Pro Know It All
Cool what do you want for it?
Old 05-05-2003, 06:55 PM
payaso payaso is offline
BIT PIMP
When you say alluminum wheels, do you mean they're alluminum? Or do you mean they're plastic that looks like alluminum? If they are metal, I want them.. Let me know..
Thanks man..
silla
Old 05-06-2003, 01:07 PM
Starting from top left going down.
The first 5.
http://zipzaps.com/showroom_hubcaps.asp
Old 05-11-2003, 01:46 PM
nouseforname101
I want the cobra SVT hubcaps & a civic body & a porshe body.
How much for each item
Old 05-11-2003, 07:10 PM
The prices are listed. 5.00 bucks for each body. the rims are 2.00 dollars because they are in the porche body set. not the cobra.
Old 05-12-2003, 07:13 PM
nouseforname101
You got a pic of the Eclipse?
Old 05-15-2003, 07:00 PM
I dont know how to post the pic. I took it off the ZZ website and editied it in paint but how do I get it from paint here?
Old 05-23-2003, 08:59 PM
Hey, I am willing to sell anything at almost any price. Email me at draco909@hotmail.com
Old 06-05-2003, 04:47 PM
I need help with the picture
Old 06-05-2003, 10:49 PM
2G2SILVERSTRAT 2G2SILVERSTRAT is offline
im rick james bytch
Send a message via AIM to 2G2SILVERSTRAT
ill give you 1.50 for a rear axel and a set of front knuckles if they still have the wheel hubs attached...?
Old 06-13-2003, 01:32 PM
Can you please be specific
im gettin 1 99skyline XMODS Mods and Projects 9 12-20-2004 12:47 AM
Gettin' an Xmod!!! da510 XMODS 2 12-10-2004 05:36 PM
gettin your race on.. VaTifosi XMODS 10 11-25-2003 08:03 AM
Sellin stuff Go0ty For Sale/Trade 16 03-04-2003 05:55 PM
Body Swappin and sellin RacerXero Bit Char-G / MicroSizers 4 11-30-2002 09:57 PM
