06-03-2003, 03:41 PM
What??? Charging dual cell with original charger???
Sorry for the long subject title, but i have something weird goin on.
I did a dual cell using the original 50 mah nicd cells from broken bits, but when i put them on the unmodified charger, it charged, and ran the full time. Isn't it suppose to screw up?
06-03-2003, 04:13 PM
Feh
well since they are only 50 mah they arent to big to were they wont change enough...if you used like 110 mah cells then you would get bad run timeing so you would have to charge twice or use direct charging
Give me a moment in which I well never AWAKEN
06-03-2003, 05:40 PM
well i made a direct charging mod for my 80mah and that took to long so i added an extra battery now it charges in 60 sec the battery is warm i pull it off and it lasts a good while i would say 10min
06-03-2003, 08:38 PM
Feh
yeah he didnt need to mod at all because those batt were so weak...will he might as well get a 110mah batt its more powerful then both hes 50 mah ones
06-04-2003, 07:08 PM
Hey, watup
I only used the 50 mah nicd's because they were just left overs from my failed projects and/or accidentally broken bits
I already have a 150 mah dual cell that uses a separate charger.
