11-27-2002, 09:20 AM
C:\WINDOWS\DESKTOP\
Yet Again I Need Help
And that's my word and i'm stickin to it.
05-14-2003, 04:40 PM
Feh
that usually menas the battery is dead
05-14-2003, 06:17 PM
switcher
or the battery is bakward
good luck
05-14-2003, 06:22 PM
MASTA POOOOOOOOOOOOOOTANG
The problem is the 150 mah nimh cell is not making full contact to the positive and negative plates. the reason why the car is working is because when you charge it the energy skips the battery and straight to the pcb board and now you probably busted your pcb chip because it had no where to store that burst of energy. That is why i always charge it for 5 seconds then take it off to see if it works even a little bit so i know that there is contact. Also with 150 mah nimh cells, if i recall, you must bend the tabs that hold the battery a little bit torward the middle so they are shaped like this +/___\- get it? before they were like this + |__| - and after they should look like this +/___\-
*EDIT* however dont bend them 2 MUCH LIKE THAT PICTURE it was just an example. Bend just a tad enough so that the tab will lean forwar a little bit (you can feel when its bending and when its bending forward)
MICROSIZER PRO:  2 SPEEDS, 1.3 NIMH, 49 MHZ, SKYLINE R34 GTR custom paint, pull back wheels, blue head lights
MICROSIZER SPORT:  1.3 nimh, rest is stock
panther=  2.4 nicd, rest is stock
MEGATOYS rc:  rest is stock
bitchar-g:  rest is stock
05-15-2003, 02:16 PM
Independent Motorsports
thats a good explination there calsonic...
05-17-2003, 07:07 PM
Feh
yeah will about 100 charges and they do that exactly
05-17-2003, 09:08 PM
new batts are a good thing as along as u install them right
05-18-2003, 01:46 PM
Feh
yeah
