Old 05-16-2003, 04:40 PM
dr1zz's Avatar
dr1zz dr1zz is offline
phear meh..............
Question ? bout peak chargerrs ?
pirahna digital peak charger, can you just connect a charge base off a controller to the input and charge that way?
here is the link topirahna charger
Old 05-16-2003, 05:04 PM
flatlander_14's Avatar
flatlander_14 flatlander_14 is offline
2 Slow and 2 Curious
Send a message via AIM to flatlander_14 Send a message via Yahoo to flatlander_14
i was also wondering about this. i did a layman's cell mod to one of my clones and it is crazy fast, but i think i could get more runtime if i peak charge the batteries. i was wondering if you could use a wire to connect the charge leads of a charging base to the spots where a AA or AAA battery go on a cheap-o AA/AAA charger. has anyone tried this?
Old 05-16-2003, 05:38 PM
dr1zz's Avatar
i have one of those rayovac nicd/nimh chargers for AA/AAA/9V batts. so i made a spacer so the 1/3AAA batt sits snug. this works fine and i get plenty of runtime, but the pain is the fact that i have to open up the car to get the batt out and charge, im gonna break a wire sooner or later.
i tried to connect the charge base to the leads and it wont detect the batt for some reason or other.
i want to buy a peak charger that i can just connect the charge base to and slap the car onto the base. and so far, this pirahna charger is the cheapest one i found that will charge single cell.
ive read that peeps are doing this with other types of peak chargers, most of which are in the ~$100+ range.
Old 05-16-2003, 05:41 PM
too bad it only has a minimum charge capacity of 50mah the button cells are 40mah. what if i selected 2 or 3 cells (however many are in the car) and set it to 50mah? would it automatically shut off?
Old 05-16-2003, 06:01 PM
Buzzbait's Avatar
Buzzbait Buzzbait is offline
Yes. You can just take the wires running from a charging base, and run them to the bare wire connectors. No problem..
Old 05-16-2003, 06:14 PM
Awaken's Avatar
Awaken Awaken is offline
Feh
Send a message via AIM to Awaken Send a message via Yahoo to Awaken
couldnt you get a donor charger base off a bit controller and connect it to the peck charger so it fits on the bit prefectly? just a thought
Old 05-17-2003, 11:43 AM
Namuna's Avatar
Namuna Namuna is offline
Well, if this picture helps...
This is my Peak Charger (Dymond Super Turbo Charger) sitting on top of my Power Supply, connected to a Bit Char-G charge bay that I modded from a controller.
Notice how I wire from the charge bay to the Peak Charger.
Old 05-17-2003, 06:33 PM
dr1zz's Avatar
dude..........sweeeet........
namuna, nice.........what mA charge rate do you use?
Old 05-17-2003, 06:57 PM
Awaken's Avatar
Feh
like i said you should wire a charger base up so you dont have to hold the wires on the car hoping they are touching and charging it
Old 05-17-2003, 08:48 PM
dr1zz's Avatar
lmao
awaken........wake up and read prior to post.
Old 05-17-2003, 08:50 PM
2fast2furious59's Avatar
2fast2furious59 2fast2furious59 is offline
Independent Motorsports
Send a message via AIM to 2fast2furious59
dude that is awesome
Old 05-18-2003, 12:09 PM
Namuna's Avatar
What I LOVE about my setup is that I've got a charge bay for my Bits, Zips, Maru, Epoch and using battery holders I can charge NiMH and Nicads too.
As far as charge rate goes, if i'm in a rush I charge at 1amp (1,000mA)...But if I want a more proper charge, 800mA seems about right (this is for ALL the different types of Bit batts, whether the stock 50mAH Nicads or the 160mAH NiMH)
Old 05-18-2003, 01:24 PM
Awaken's Avatar
Feh
hehe sorry im not to bright i think my light bulb burned out a few years ago
Duratrax Piranha Peak Charger help jkellington Bit Char-G / MicroSizers 2 06-16-2003 03:33 PM
question about a peak charger. (regards to power supply) Clint Miscellaneous Discussion 1 03-06-2003 10:31 AM
Using peak charger for Epoch, what is a good cutoff? rmelancon Epoch RC1/43 5 02-28-2003 10:32 PM
Peak Charging? zzz ZipZaps 1 12-26-2002 01:50 PM
Peak Charger? vwarner Bit Char-G / MicroSizers 0 11-05-2002 04:24 PM
