Old 04-27-2003, 01:29 AM
Calsonic_racer Calsonic_racer is offline
MASTA POOOOOOOOOOOOOOTANG
Zip Zap Help Plz
hey i just did a tri-cell with my zip using electrical tape cuz i was pist off at soldering. all the batteries were connected in series. next i soldered a wire from the positive side of one battery to the positive charge plate. next i went to the last battery in series and soldered a wire from the negative charge plate to the negative side of the battery. i slapped it in carefully makeing sure all the wires were properly fit. then i slapped it on my 6 v charger and IT DOESNT WORK. wont even turn or anything. can anyone help? everything is connected im positive. any help?
also on the new 2 FAST 2 FURIOUSE convertables shells how are you supposed to fit a tri cell or dual cell in the car if you flip the pcb over? the seats in the convertables sink down below the top of the car so theres less room. does it still fit? i know some of u guys have it. also how duz the skyline look? better than the BITCHAR-G R34 SKYLINE GTR? or as good as the r32 skylines?
MICROSIZER PRO: 2 SPEEDS, 1.3 NIMH, 49 MHZ, SKYLINE R34 GTR custom paint, pull back wheels, blue head lights
MICROSIZER SPORT: 1.3 nimh, rest is stock
panther= 2.4 nicd, rest is stock
MEGATOYS rc: rest is stock
bitchar-g: rest is stock
Old 04-27-2003, 11:25 AM
Ultimate's Avatar
Ultimate Ultimate is offline
Ultimate ZZ racer!!!!!!!!
When you soldered to the battery you probably burnt the battery.
Old 04-28-2003, 12:09 AM
chelboed's Avatar
chelboed chelboed is offline
Epoch's R Bett'R
I believe he just said that he didn't solder, he used black tape.
I would take it apart and solder everything. You probably have a cruddy connection somewhere. Make sure to check the wires to the PCB and ensure that they are not loose. Use a bit of sandpaper on the cells before you solder them, or your mom's nail buffer pad thing. It will be easier to solder with a rough surface.
Old 04-28-2003, 03:26 PM
Ultimate's Avatar
Re: Zip Zap Help Plz
Uh yeah he did.
Zip Zap SE FAQ Bad Company Tips, Mods and Reviews 4 11-16-2006 08:21 AM
My Zip Zap GuiltyEnder ZipZaps 1 04-11-2004 09:38 PM
Microsizer and Zip Zap lot intermision For Sale/Trade 1 12-22-2003 11:19 AM
