Old 04-16-2003, 05:41 PM
BabyKiller's Avatar
Soler powered charger
http://www.allelectronics.com/cgi-bi...-60&type=store
use one or two of them(in low light conditions) and just solder a charging base to it considering the low 40 mA and 3v it would only be fit for a single cell if you resist the 3v to about 1.5-2v
+ (4.8v)
BabyKiller's Avatar
or simply atach it to your car
+ (4.8v)
Old 04-16-2003, 08:17 PM
InGaN's Avatar
InGaN InGaN is offline
GaN: Blue
To get that to charge the car in 45 seconds, you'd need around 30 of these and bright sunlight.
< Plane construction paused>
Current Progress: 0%
Old 04-17-2003, 03:55 AM
Spanky's Avatar
Spanky Spanky is offline
Mr. Goop
to charge you have to look at voltage.. if your charging a 1.2v bat with 4 of those panels thats 12 volts(provided they are wired correctly) i think that the low mah output would affect the capicity of your charge.. everyone thinks that these thing need to be baking under the sun for them to work... if that was the case then they wouldnt be making them... they do work with partial sunlight. Sunlight is the key.. not a lightbulb. its a different brightness. anyway there was a post in here about the solar powered bit. and if you go to the site that the solar car is on it will give you more info on the output on these things.. i emailed the guy and he told me that the output was suprising and that they would even run on cloudy days.. just so long as it wasnt dark outside.. but lightbulbs arent the key.. natural sunlight...
Old 04-17-2003, 06:31 AM
BabyKiller's Avatar
i know
+ (4.8v)
car not running long, and some charger help.. tegboi Bit Char-G / MicroSizers 2 10-12-2008 09:09 PM
IC3 Charger Question Gaian XMODS 8 01-06-2004 12:24 AM
8 car charger for Epochs rmelancon Epoch RC1/43 2 12-11-2002 09:39 PM
