Old 12-16-2002, 09:33 PM
wild03 wild03 is offline
Custom gear ratios
Here's an idea for those with lots of torque. Slow taking off but should give you a higher top end for those land speed record runs.
http://www.geocities.com/wdiaz03/wild_ideas.html
I believe that with red Gears the ratio drops to a little over 2:1
I'll have to do the measurement again!
Old 12-17-2002, 05:59 AM
ib311's Avatar
ib311 ib311 is offline
Promoted to Pleb
How do you measure ratios?
Old 12-17-2002, 09:02 AM
Since ratio is just the number of turns one gear turns for every turn of the other gear, You can get a rough measurement by putting a small mark on the tire and a small mark on the motor pinion. Let's say on the 12o'clock position. Start turning the tire slowly until you reach 12o'clock again and count the number of turns the motor pinion makes. So one turn of the tires will give you a couple of turns on the motors.
With the blue gears for every turn of the tire I get exactly 4 turns on the motor hence 4:1 gear ratio. Red gears gives a little over 2 but I'm still gotta double check
You can also use the number of teeth on the gears and calculate the ratio but the other method will give you a good approsimation.
Custom Crawler Gear Mod hartoy53 ZipZaps Monster Truck 3 06-30-2008 02:44 AM
Monster Truck and Upgrade Gear Ratios? rfnagel ZipZaps Monster Truck 33 02-16-2005 08:44 PM
Equation for scale speed and gear ratios. Zephyranthes Bit Char-G / MicroSizers 0 02-10-2003 06:34 PM
How to about custom wheels to a stock gear box slotsurfer Auldey (All) 0 01-18-2003 10:57 PM
Wheels and Gear Ratios NMT RACER Bit Char-G / MicroSizers 5 10-08-2002 05:55 PM
