Old 12-03-2002, 01:55 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
custom front suspension complete for 1:16
aww yeah i rule
for the front suspension, i removed[cut off] the original ends of the steering cover that hold the knuckles in place, i made a new one out of an old plastic folder with the knuckle holes closer together, so that there is a slight camber increase of about 4-6mm...and i also shaved the top of the knuckles thinner to get more camber
next i put the original back ontop...and with that on, my ride height is higher, because the plastic folder pushes the knuckles down....its very flexible, and acks just like a spring.
i will have to make a diagram for this also...now my ride height is matched with my rear, which was before a little higher.
but in general,....when in normal position, the camber angle is almost normal, very unnoticable, but when u push down the front, the camber angle increases, and when u release, it goes back to normal....sort of unrealistic, but....the countersteer is more improved on tile for some awsome drifting...
ill make a diagram tomrrow.
Old 12-03-2002, 02:08 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
i havent tested how it works outside yet....im trying to save my tires these stock tires are the only ones i have for now.
Old 12-05-2002, 04:52 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
sorry guys, ill make diagram later...
me=lazy
Mounting Mini-Z bodies on Xmods neurokinetik XMODS Mods and Projects 18 12-28-2005 05:13 PM
Front suspension in rear T Man XMODS Mods and Projects 14 06-27-2005 05:35 PM
better front suspension springs for SE? daver ZipZaps SE 1 01-22-2005 07:54 PM
more front suspension travel theone&only.... ZipZaps Monster Truck 0 12-26-2004 11:55 PM
Fully Adjustable Front Suspension Steve ZipZaps 6 11-16-2002 10:57 PM
