heres someone who did a project using that motor.it went i think about 20mph on 4cells.
click here
it does take minor modifications to fit in the car suchs as using a bevel-pinion and trimming the plastic motor mount and shimming it up high enough for the gears to mesh.there is some info on the motor on the link and pics to understand what im talking about.
good luck
i saw you sig and does you car still have 6cells?i dont think that it will fit if you use 2 batery holders on the top of the car.i know that it would surely fit if you solder the batteries together using 3 on each side...but this would require a pro charger.lithiums should work great though.
later
imhinOaChickeN
