11-29-2003, 01:38 PM
Extended Range?
i think i may have found a way to increase the range without adding an antenna. if you look the where the antenna comes out of its PCB you'll see two green resistors. if you replace one of them with a bigger resistor it will extend your range. last night when one of them blew and the range went down to 3ft i was going to just jumper it with a wire but that made it even worse. so i took one out of an old radio and put it in and the range is at least back to what it was. i havent had anyplace big enough to drive it on yet cause its snowing.
11-29-2003, 02:34 PM
sleeper mall civic
hey u read my thread about the civic on fire, if it did short out can i just use the pcb (i think thats what it is) i took from a skyline
douglascounty!!!
11-29-2003, 03:22 PM
you could take the entire electronic system from the skyline if you want. they're all the same except for the "new" & "old" versions. check the crystal plug and whichever one sits lower choose that one.
11-29-2003, 09:39 PM
sleeper mall civic
douglascounty!!!
12-02-2003, 08:43 AM
if you take it apart and look at the little PCB where you plug the crystal in there should be two small resistors right next to where the antenna plugs is soldered on, if one of them is green and the other is black you have to replace the black one. take the entire system to some electronics store that isnt RS and ask someone there if they can find it. if they cant find it or cant order it take it out of the Skyline and replace it. or you could put any resistor in and it should work.
12-02-2003, 10:36 AM
0reZepyT
what value of the resistor did you use? do you happen to know the resistance of the original one? (at work so i can't measure it myself)
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
12-02-2003, 11:21 AM
im at school right now ill get home in about 3 1/2 hours. right now i have no clue what it is all i know is it works. and i can identify it by the colored rings on it right? i dont have anything to test it with. and i dont know what the original is.
12-02-2003, 12:45 PM
0reZepyT
i think it should be the same color code as regular non-surface mount resistors
12-02-2003, 04:55 PM
sleeper mall civic
well im not that much in a rush to get it fixed anymore cause RS is ordering me a new chasie and i hope the let me keeep the old one then ill get that fixed with the parts i got from and old sky and ill have 2 but with 1 diff crystal thanks for the help
douglascounty!!!
12-03-2003, 08:22 AM
entire new chassis? with electronics and all? how much did that cost?
12-03-2003, 08:44 PM
sleeper mall civic
they should be giving it to me for free cause when i told her about my problem she said she would order one and didnt say anything about costing me anything (if i have to pay ill just tell her i cant and get her to hold it for me till i get enough money cause i got to get presents for the family)
douglascounty!!!
12-03-2003, 09:31 PM
Fred Obando Rox My Sox
how about pics of the process
AIM: CoryRSmith37
2000 Honda Civic,
Stage 2 Drag Motor,
LED Lighting Kit,
AWD Kit,
Hard Treaded Tires,
Metal Bearings,
All at a 30% Discount, OORAH!
12-04-2003, 08:16 AM
im not really sure if it extends your range or not because i havent had anywhere to test the range except in my house from one end to the other. but thats through walls and ill have to take some pics when i get home
01-07-2004, 03:33 PM
one quick question, it may be stupid but i doubt it.
when you guys are saying PCB are you guys referring to the cars PCB or are you calling the remotes circuit boards a PCB?
which device do i need to work on is what im asking here.
01-08-2004, 08:03 PM
the cars electronics. there is one large L shaped board and one smaller board where the antenna comes out of. thats the one im talking about. i havent heard about anyone having a fried controller.
