Old 09-05-2004, 09:26 PM
Burnout Burnout is offline
Servo Problems
I'm having some problems with my servo, no response when trying to turn the wheels, so I took it apart and found a little blue wire was disconnected. So I assuming this is my problem. Does anyone know where does it come from and lead to?
Old 09-06-2004, 05:00 PM
ninja828 ninja828 is offline
yeah, looks like you found your problem. that blue wire should be attached to the drain of the steering fets. if you look at the servo where the blue wire came from, there should also be a red wire which should lead to the drain of the fet furthest away from the servo. the blue one should lead to the drain of the steering fet closest to the servo. all ya gotta do is solder that blue wire to the drain of that fet and you'll be racing again in no time
Old 09-06-2004, 05:31 PM
viperdout's Avatar
It's Really Fast!
http://support.radioshack.com/doc/600/rec600-xmods.pdf
See the blue wire from the servo? That's the one that's loose on yours. Just use the diagram.
Project Bad Brushless:
Just say no to giant sigs.
Old 09-06-2004, 10:55 PM
Thanks for all the help guys!! I'll probably have it solder tommorrow, Thanks again!
Gen 1 Servo to Evo Elec Compatibility Jshwaa XMODS Mods and Projects 0 02-18-2006 08:50 AM
need help! servo problems ?!?!?! xmodddddd XMODS 1 04-09-2005 11:46 AM
Steering problems in a white supra johnfish XMODS 4 11-18-2003 04:15 PM
Servo options... binaryterror TTTT 4 08-29-2003 08:24 AM
Verticle Mount Servo crusader4x ABC DTM Parts and Hop-Ups 10 02-04-2003 03:55 PM
