04-06-2004, 02:08 PM
Sp33D D3m0n
main board
does any one have a diagram of the manin board i have oine that is screwed and i need to figure out where to hook things up
i will also take pics of the bottom of the board where the battery wires connect
Getting back into the hobbie w00t!
04-07-2004, 05:27 PM
BC posted one a while back in one of my threads i cant find the thread though. ill see if i can find the pic for you.
04-07-2004, 07:29 PM
Sp33D D3m0n
thanks i will keep mjy eyes open now that i now where to look
04-08-2004, 09:33 PM
Sp33D D3m0n
are there any electronics pout there that will fit in a xmod with little or no moding that are cheap ? or should i just try to get anpother board if i cant fix the one i have
04-08-2004, 09:53 PM
Go to www.atomicmods.com. Rob has alot of pictures of the board. If you look around, you might even find a drawn out schematic of the board. What part of the board are you interested in? The ESC?
Here's a schematic of the stock ESC. This, folks, is what an h-bridge is.
This schematic is true to the parts references on the xmod board. The DC voltage sources are replicating the pins of IC1. I did this to simulate the circuit and test its functionality. The box looking thing in the middle "xmm 1" is a multimeter. I used it to replicate a motor to test the changing states of the voltages and currents. This is your ESC.
I have a design of my own that should be able to handle 20x's the power as any h-bridge possible could with the small 8 pin IC's. I'm going to use TO-220 power FET's and restructure the circuit a little to make for better FET driving. There has to be a level shift between the weak 0V to 3.5V PWM signal and 16V+ DC. So you need to encorporate driver transistors to help fully turn the power FET's on and off, with a little help from the very power that they are switching on and off to the motor. A little pre-amplification, if you will.
Sorry, no vids for now.
04-10-2004, 07:19 PM
i found it. i dont know if it is it though. if you need it just tell me.
04-18-2004, 10:13 AM
Sp33D D3m0n
ok heres a pic of my main board from when i couldnt soder and i was replaing the battery wires. it wasnt smart but i hope it can be fixed the board isnt fried i jusr dont no where to connect cause some of the connections are gone and what not.
http://www.stargazersurge.com/surge/.../mainboard.JPG
if u no where to connect can u use ps or paint to show where to connect every thing
04-18-2004, 10:40 AM
Here you go, man. Hope this helps.
04-18-2004, 02:57 PM
Sp33D D3m0n
thanks
that might help i will work on it when i get some more suplys
