Old 10-14-2003, 05:45 PM
DAMZer's Avatar
DAMZer DAMZer is offline
Xmods with Standard Controllers? Help
Anybody tried a standard perfex or M8 controller? The cystals are standard 27mhz and work in my sotck z with an M8, but no luck controlling the Xmod.
Old 10-14-2003, 09:42 PM
SuperPede1 SuperPede1 is offline
Send a message via AIM to SuperPede1
I would like to buy one and compare it to my mini-z but if regular transmitters dont work you can forget that, it should work just fine and I dont see why it wouldnt.
My yellow RX7 clone:
I have 3 more micros but it wont let me put all of their specs in this sig.
Old 10-14-2003, 11:02 PM
RCDuggiedug RCDuggiedug is offline
Hi, I'm new to TinyRC. Probably the reason the radios don't work is the type of pulse code might not be compatible. Airtrinics, Futaba, JR and others don't always work with one anothers receivers even if they all use AM. Some have a negative pulse and some have positive pulse. There is AM, FM and PCM modulation also. although I think all 27MHZ radios use AM.
>What happens if I press this button? Formatting harddri....<
Old 10-15-2003, 01:26 PM
DAMZer's Avatar
I don't see why either, as I said, the crystal sets work fine with a mini-z and either the perfex or M8 and can you beleive 6 pair for less than 20 bucks!!
I am aware that in the FM band there are differences between manufacturers and their cystal sets, but wasn't aware it crossed over into the AM 27mhz range. Live and learn..........
I am still at a loss as to why it doesn't work. Any electronics gurus out there who have the xmod and standard transmitters, clue us in, especially if there is a fix!!
Thanks!
Old 10-15-2003, 10:55 PM
ripper7777777 ripper7777777 is offline
I'm not a guru, but I believe the problem is the fact that xmods are not true propo and mini-z controllers and others are.
Old 10-16-2003, 01:55 AM
bobcat bobcat is offline
I suspect too
you can sort of feel the stepping of the wheel and trigger on the xmod controller as you manipulate them. like when you pull the trigger on a slot car controller.
the truly proportional signal of the perfex must be lost on the xmod.
CJ's Xmods FAQ (Updated June 27th.) cj1267 XMODS 64 05-30-2007 07:43 PM
Xmods! xmodsrc XMODS 3 04-13-2005 10:06 PM
FS: XMODS **HUGE LOT: THOUSANDS OF PARTS & CARS!! Lips, Nuts, Complete XMODS, more... impression_xmod XMODS 5 05-26-2004 09:11 PM
Mini-Z VS. XMODS jerm781 XMODS 16 10-19-2003 09:17 AM
Xmods Announcement cj1267 XMODS 2 10-16-2003 04:34 PM
