Old 06-03-2003, 06:02 PM
geofroley's Avatar
R34 Skyline is God
RC Mod spring suspension
i saw it on rc mod.com heres the link:http://www.rcmod.com/mod_sussprings.html
will this make my car better performing(handling)?
Old 06-03-2003, 08:09 PM
2fast2furious59's Avatar
2fast2furious59 2fast2furious59 is offline
Independent Motorsports
Send a message via AIM to 2fast2furious59
some people have said that they handle better with them....they also lower ur car too so u get a 2in 1 effect there...if you want to improve steering alot add another steering spring so u have two...it helps...and you could also add rare earth magnets
Old 06-04-2003, 03:01 PM
geofroley's Avatar
R34 Skyline is God
plus if you use ultra stiff springs more power will go to the ground on the front wheels
Old 06-04-2003, 03:32 PM
geofroley's Avatar
R34 Skyline is God
do ya think pen springs will work?(cut to size)
Old 06-07-2003, 09:53 AM
strider_mt2k
I'm a convert to slot car tune up kit suspension springs.
All my ZZs have springs, as well as my Bit/MS clones.
Handling improves big time for speed-modded cars.
Pen springs tend to be made of steel, so they affect the steering system.
They also are a little large.
The good springs fit the steering knuckles perfectly.
The only thing you do is shorten them for steering play.
This is about the best pic I have of the results:
Old 06-07-2003, 05:14 PM
nrmcj's Avatar
nrmcj nrmcj is offline
Rice Me
hmmm, i see strider's back for a couple posts once in a while ... i was wondering... me and swavey were lookin for springs, but we cant find any of these.... slot car tune up kits... should a normal LHS have them? or... where should we be looking? thx!
Old 06-07-2003, 07:11 PM
strider_mt2k
Local Hobby Shop for me.
I hang in the Zip Zap area nowadays.
Old 06-07-2003, 09:10 PM
strider_mt2k
I have to add that the spring suspension mod was here first.
http://www.questformadness.com/
Old 06-07-2003, 09:20 PM
ph2t's Avatar
ph2t ph2t is offline
Chief Propeller Head
I still have a couple of custom spring sets left for sale.
Check it HERE
ph2t.
Old 06-08-2003, 02:31 AM
crweedon crweedon is offline
save your self some time and money and just buy some "magnet wire" from radioshack, then wrapp it around a micro precision screwdriver like anywhere from 7-15 time depending on the gauge and how you like that springyness, and when you're done with the wire you can use it for any other project you want as it is very small, or you can just tear apart a small hobby motor
Old 06-09-2003, 06:55 PM
strider_mt2k
The problem there is that magnet wire isn't rated for use as a spring, and will sag over time.
Unwind one of those springs sometime, it's different stuff.
IMO It's worth spending a few bucks to get good consistent performance on this one.
Old 09-19-2003, 08:51 PM
NeedForSpeed NeedForSpeed is offline
Send a message via AIM to NeedForSpeed
wont center
ok, i tried the mod and it didn't work, the steering wouldn't turn because of the springs. I then decided to give it up and put it all back together, but wen i did the car doesn't center anymore. Wuts wrong?
Old 09-21-2003, 06:35 PM
nxnitrous22 nxnitrous22 is offline
Send a message via AIM to nxnitrous22
spring suspension
ok, so when i added my spring suspension to my BCG, i decided to go ahead and learn the whole suspension system. On the steering mechanism inside the suspension box, there is a little spring that keeps the wheels centered when no direction is pushed on the controller. if you lose this spring, it causes your car not to center out when no direction is pressed on the controller.
I attached a crappy drawing to maybe help you understand what im talking about.
The only way i can think of how to fix this is to bend a wire yourself to match it. Unless you can order that part from somewhere, or worst-case: buy a new car and take it out of there.
Sorry to hear this happened.
Pennzoil GT-R (R-Spec II)- Front Tab Lowering, Rear Suspension Raising, Hard Tires, Green window tint
Loctite GT-R (2.8 motor)- Front Tab Lowering, Spring Coilover Suspension
Castrol GT-R (2.8 motor)- White Rims, Body Paint
American Hatchback Thing (1.8ish motor) - HEAVY body mods, metal roof cage
Old 09-21-2003, 06:42 PM
found another solution
hah, right after i posted that reply, i found a better solution of www.questformadness.com. It also has real pics and not my terrible paint drawing skills. just click http://www.tinyrc.com/qfm/racing/mod_05.htm#17 to get there. hope this helps
Old 09-22-2003, 08:24 PM
Thanks a lot for that link. I found out that the spring was still there, it was just all bent up, so I straigtened it as much as i could but it still doesn't center well, is there anything else that could have happened? Im tryin to add in any details:
I lost the little scew that holds down the front cover for the suspension area.
The centering spring is slightly bent.
The magnet came unglued.
Would any of those things affect the cantering? All I could think of would be the screw, because the magnet might line up with the screw or something. Any help would be appreciated.
True FULL suspension travel Mod zzmods ZipZaps Monster Truck 13 12-30-2005 12:49 PM
Half Drop and Spring suspension mod [PIC] iAppleG4 Bit Char-G / MicroSizers 5 07-03-2003 06:52 PM
Suspension Mod TEAM_NITRO Epoch RC1/43 Parts and Hop-Ups 3 11-23-2002 01:22 PM
Still confused about spring suspension!? shane45-1911 Bit Char-G Mods and Projects 3 10-26-2002 02:41 AM
