-   -   help a newb plz (http://tinyrc.com/forums/showthread.php?t=9151)
GHC 03-06-2003 08:45 PM
help a newb plz
i have never owned a bit charge but my friend had one and his front wheels broke off. I only own 1 zz. he gave me his motor, batt, and gears. the motor is red at one end and has a green gear to spin the gear. my q is, is this motor faster than my zz nos?
Squishy 03-06-2003 08:56 PM
uhh... have you check the zipzap forum? i'm not familar with ZZ motors...
hogjowlz 03-06-2003 09:01 PM
hmm why dont you do something crazy like "try it"
batesjm 03-07-2003 11:54 AM
If it has a red endbell it is most likley a 3.0 which is faster than your zip motor, however you may have an old zip that doesnt have the revised pcb, if not your car may not even move. Like posted above, you will just have to try it. Just a little hint, bend the terminal that touches the back of the motor tward the motor, this will give you better contact with the shorter bit motor, also when you put the motor put the contact in the 3 o'clock position.
Thats all,
Josh
midget_man1387 03-07-2003 11:58 AM
ah, the mean-spirited evil-doer, a.k.a. retarded stunt driver strikes again! :D
