-   -   Microman's Instructions (http://tinyrc.com/forums/showthread.php?t=9045)
nrmcj 03-03-2003 08:22 PM
i dun have much time rite now... so basically i'll make it short.....
i traced the whole tab (WHOLE thing, not just the part that sticks into the body) on paper, then traced that onto a card (credit card material, but it doesnt matter what you use)...some sort of plastic will do...
next i cut out 2 of the tabs, then trimmed them to Exact fit under the original tab, then glued 1 on.
i sanded the thing.... orig tab (only the part that sticks out)... leaving all the normal rectangular part on... then i stuck the second one on.. then sanded away at the first custom tab...
so basically, check out that pic in the rating thread... and use crazy glue... that stuff's nuts... hope that helps!!
and any questions? i'll reply when i get the chance..
MicRoMaN 03-03-2003 08:52 PM
Ok thanks alot man.
nrmcj 03-03-2003 08:57 PM
no problem :cool:
