Joysticks
1 Attachment(s)
Joy sticks are a quick, easy mod that makes holding the control easier and more relaxed. Not as much effort to push the buttons either. All you have to do is to get a pair of those screw thingies that are on the connectors for computers. Make hole in the center of your buttons using a drill. I used a wood boring bit which requires no electrical stuff, just your hand. I'm pretty sure a pointy knife should work. Get it to the right size, and screw your joysticks in. Make sure you don't screw them in so far that they touch the pcb board. Secure them with super glue or epoxy. You're done!
I whited out the FCC ID so if anybody tries using that one to get a new chassis, it won't be traced to me. |
| All times are GMT -5. The time now is 02:44 AM. |
