What tool?
What tool do you use to cut the back window wider so the dual cell can fit?
I'd use an x-acto knife personally. Easy, quick, and sharp. :D
dremel
i used a dremel cuz i suck with an x-acto knife:)
Its a little bit messy, but you could also heat up an old knife or something over a flame, and it will slice through the plastic very easily. Then, file the sides to make it even.
i saw at canadian tire a soldering gun tip that was flat with a blade for melting plastic (i should've bought one)
yeah, that sounds like a good investment
i always thought a canadian tire was a snow shoe.
next time im there ill try to remember to get one but on my way there i should pick up some tim hortons doughnuts LOL:)
heres what i'm talking about
http://www.tool-up.co.uk/Images/00/00/21/00002184.jpg and http://www.tool-up.co.uk/Images/00/00/21/00002191.jpg |
'm using a scalpel so could I just heat it up with a soldering iron?
i would think so:)
you could use a candle, but it will char your blade, though.
| All times are GMT -5. The time now is 04:15 AM. |
