Pull-Back Tires Fit on Bits/ZZ's!
The ultra-sticky Tomy Pull-Back tires DO fit on ZZ & Bit rims! They do have to be stretched over the wheels, but they fit very well. And the performance is fantastic!
The front, narrow rims will fit pretty much as-is. The wide rears need to be trimmed on the inside (for gear and chassis clearance). The wide rears definately have a wide-faced tread, even trimmed on the inside! These tires are MUCH stickier than even my softest clone tires. Try it! John P.S. I want to clarify- use the pull-back tires on the REAR, larger Bit & ZZ wheels. |
| All times are GMT -5. The time now is 03:51 PM. |
