-   Bit Char-G Parts and Hop-Ups (http://tinyrc.com/forums/forumdisplay.php?f=11)
-   -   R-spec, no longer works (http://tinyrc.com/forums/showthread.php?t=8159)
trinitron2k2 02-09-2003 05:39 PM
I bought an Rspec motor from tinyrc, it worked great for the first two weeks. Now it can't even turn the wheels. Does any one know how to fix this? (its not the car( I tried the motor on both my cars and it does the same thing))
Any help would be apreciated
Namuna 02-09-2003 05:58 PM
Are your gears properly meshed?
To test, put the motor in and hold the car up, then manually spin the rear wheels...Does it spin readily? Or is it an effort?
If it's an effort then the gears aren't properly aligned, keep fiddling with the gears until the rear wheels can spin easily and your motor will work right.
trinitron2k2 02-09-2003 10:42 PM
no, the gears are fine...when I take the gears off and let the motor run all by itself, it spins very slowly...and hardly makes any noise.....so its not the gears...
trinitron2k2 02-11-2003 05:39 PM
no one else has any suggestions?
Redfire 02-11-2003 06:35 PM
The same thing happened to me, and my R-Spec.
Try charging it like 4-5x, because it seems to drain MORE out of the battery than usual.
trinitron2k2 02-12-2003 12:15 AM
charged it 4 times, put the car on the ground, pressed forward, a wild jolt!, and after five inches back to a crawl :(
I wonder what is wrong with it :confused:
Racer9 02-12-2003 03:20 PM
try WD-40! It works like a dream!
trinitron2k2 02-12-2003 04:22 PM
just tried the wd40...unfortunately it had no effect
trinitron2k2 02-12-2003 07:13 PM
Just did the double cell mod....OMG....incredible....the rspec was soooooooooooooooooooooooooooooo fast, unbelieveable amount of torque/speed, so I guess its ok now....thanks guys sorry for the trouble
