6 x 4 articulated Bit Semi truck!
1 Attachment(s)
Here's my second Bit Char-G project in progress, a three-axle, 4WD, 2WS, dual-motor, articulated 1/100th scale semi truck.
Mods & features include, but are not limited to: Real carbon fiber flexible lower chassis plate Semi-independent articulation at every wheel Two 1.0 motors with low gear sets (one per drive axle) Bit Racer treaded tires Choro-Q body This is most definitely a work in progress. I will be adding more batteries, not in series for speed, but in parallel for runtime and weight. I also obviously have quite a bit of body work to do, to make it look professional. Currently, this truck can climb a 30-40% incline, stop, back up a bit, and start again (no running start!). Full details of this ongoing project can be found here: http://www.ultimaterc.com/urc/land/projects/6x4bit.asp |
1 Attachment(s)
Here's some rear articulation...
one word
NICE |
Very cool! :cool: Is the articulation via the CF H-plates?
Not precisely h-plates, but the same concept. The bolded link in the original post will take you to the project page, which has more images, including a picture of the underside of the chassis and a view of the CF stock I used.
| All times are GMT -5. The time now is 11:45 AM. |
