-   Dynamite Rocket Racer (http://tinyrc.com/forums/forumdisplay.php?f=48)
-   -   Getting the DRR to proper spec's. (http://tinyrc.com/forums/showthread.php?t=7319)
fatdoggy 01-23-2003 09:25 AM
I've decided to put some decient radio gear in the Drr, not that what is in it sucks but I hate the perminent reverse on the esc so for now it's out of the car.
I'm going to keep the motor, tyres, servo and body for now. In goes my keyence A07rz and a mini-x Rx that I bought from tiny a while ago. It only just fits and it's a squeeze at that. Also found some nice kodak AAA 750mah cells here and figured a good 6 pack would be a nice addition. Have any of you tried them?
Cheers.
P.s. I plan on adding foams, bearings, a more spacious body and probably an orion elite mod later on.
fatdoggy 02-12-2003 08:18 PM
1 Attachment(s)
All right finally got around to it. I got some radio shack 700mah AAA's, and built a 6 pack(the cells were a major rip but for convenience...... Once I got it all set-up the diff went a little weird again but I threw a bit of thick grease on it and it's back to normal. Now the left bias popped back up again. I now have, when looking from the front two shims on the front right(one thick and one thin) and one on each of the two back left motor pod mounts(both motor shims from an old p2k). I also reemed out the top deck as ModemJunki suggested(thanks for posting that, it really helps). The car is really sweet now, no annoying reverse immediately(I've got my esc set to 3 sec rev delay)and no left bias. The body fits fine as well which was very lucky. Not blazing speed but the motor is stock, it's perfect speed for my deck though.
Cheers. :D
djpj 02-12-2003 09:11 PM
I'll buy ure stock ESC/Receiver if your not gonna use it. private mail or email me. Thanks.
-djpj
catman25 02-12-2003 10:00 PM
one thing i notice is tiny sells bearings for a minix which fit in the drr. 2 in each wheel and 2 in the rear shaft ..look under mini x parts ..17.00 shipped ..cant find um any where cheaper then 25.00 so not sure if it works but they fit :-) i got 6batts. with sauced foam and a coreless motor...and im running it on my 40x40foot infdoor track ...hopefully ill post pics..im just bumbed then there isnt more people i know rich enough or into mini rc.i need new friends :-) what wouls be a good surface for tracks??some one said sugar water ???huh ??but i was thinking carpet .but whats best ?
