Need a little help
1 Attachment(s)
well, my motor sounds like it is about to explode, and I need help on what I should do about it. It's a 1.0 and I've had it for about 3 weeks.
sounds........awful.......my sounded worse, it sounded like a kid screaming.......
anyways, it sounds like its dirty or something, why don't you try to clean it or maybe lube it...... |
i hear axles, that may be your idler gear making that noise.
sounds like a gear to me, lube them or just go buy a new motor.
It sounds like dust in the space where the piece of metal that turns the first gear meets the outside of the motor.
if it was me i would have thought it was a gear
try lubing
what lube would you suggest?:confused:
graphite or VASELINE
hehe, im just kidding about the vaseline(that'll kill the car) yu should use graphite lube or some sort of WD40 |
When my motor was making awful sounds....a combination of WD-40 and baby powder worked for me
I sprayed the WD-40 where the shaft meets the brass bushing and dunked it in babypowder afterwards.... just make sure that you don't go overboard and coat the whole thing in WD-40 or else dirt and more crap will stick to it.... |
that quote, i put buisness and with backwards, lol...
sounds like a bearing place is dry. when these motors die its hard to fix them. 1.0s are cheap. if you want another one you can get one cheap here-
http://www.tinyrc.com/shop/products.php?pid=2 along with lots of other (faster) motors. yes. |
| All times are GMT -5. The time now is 07:06 PM. |
