-   -   20Mhz Bit modification (http://tinyrc.com/forums/showthread.php?t=6788)
arceeguy 01-15-2003 09:06 PM
So, you sick of having frequency conflicts with your buddies? Easy fix, mod your car to run on a frequency nobody else has! It's pretty simple to do, but you'll need some soldering skills. Here is the procedure:
1: Buy a 20Mhz crystal. They are less than a buck from DigiKey.com. I got mine from a junk 386 computer motherboard. (20 Mhz processor :D )
2: I replaced the 27.xxxMhz crystal in the Tx with the 20Mhz crystal.
3: Re-tune the Bit PCB for maximum range on the new frequency. This is probably the hardest part because I had to melt the wax out of the tuning coil to get the tuning tool in to turn the ferrite slug in the coil. You MUST use a plastic tool, I got mine from a local electronics store - Radio Shaft may carry them too.
You don't need to tune the transmitter because it doesn't have a LC circuit on the output stage.
Other frequencies are possible, but if you stray too far away from the cars original frequency, you'll have to modify/replace the tuning coil and/or the capacitor across the coil to re-tune the circuit.
The mod didn't increase the range any, but then again - it didn't hurt the range either! I get about 12ft. before it starts to stutter. The test mule is a LXX clone.
t-squared 01-16-2003 06:32 PM
would the 20mhz screw up a 27mhz car?
arceeguy 01-16-2003 06:40 PM
I've had no problems with interference. The 7Mhz spacing is adequate to prevent interference. If you put the Tx antenna right next to a 27 or 35Mhz car it will control it, but the same is true with the "regular" frequencies.
Factoid: did you know that 57Mhz in in our TV frequency band here in the US? (VHF "Lo")
DarthRacer 01-16-2003 10:09 PM
Did you also know that TV channels are 6Mhz apart?
BigPappaBuck 03-10-2003 06:47 PM
Has anybody else did this with their cars?
I was thinking of making a 40 mhz car out of a 45 mhz car.
strider_mt2k 03-12-2003 04:42 PM
Very clever idea!
This should be in Bit Science I think.
sm2osley 03-12-2003 06:07 PM
what does Tx mean:confused:
Squishy 03-12-2003 07:16 PM
The transmiter (controller), I believe.
arceeguy 03-12-2003 07:38 PM
I haven't tried a 40Mhz custom yet, but the 20Mhz car is still running fine. It really does come in handy when a bunch of people get together. I can always use my favorite car. Isn't 40Mhz a "legal" frequency in Australia? Anyway, re-tuning a 45Mhz Bit probably wouldn't be a problem.
BillyP 03-13-2003 02:10 PM
I found 20MHz crystals at All Electronics with 20MHz resonators. Can you use a resonator in the car to change it's frequency?
arceeguy 03-13-2003 02:21 PM
I don't think a ceramic resonator will work.
You'll need a "real" quartz crystal for the type of oscillator that is in a Bit transmitter. The crystals are cheap enough anyway.
