Car for some reason is slowering down?
I dont know why, its not the motor, but my car isnt as speedy as the others. like when pressing forward with another chassis, it goes fast. but when pressing forward with this chassis, it doesnt have that pick up speed as with the other. but top end speed is almost there. its also older then my otheres. no hair in the gears, and motor has NO problem. is the battery getting old or something? its only 1 month old. mm.. i dont know, and i also have a 49mhz to trade for a 45mhz
had that problem too, i had a hair in my FRONT wheels
if not , then just loosen your front wheels a little bit(by pulling the pins out a little more) the pins might be pushing the wheel in too tight |
im not getting u man, explain in more detail:o
Try to cycle your motor.
there is a pin holding the front wheel onto the knuckle.
pull on the wheel so that the pin isnt pushing so hard onto the front wheel |
And remove any and all hair from those pins.
Go
If you want a new car battery got to target and buy a kit racer for cheap
________ Ford Gt90 History |
i think i need a new 27mhz chassis. anyone have?
Giving up already? Swap your battery and motor.
i also think my motor died. its not causing that effect with slowing down, but i think its burnt. it doesnt go as fast as it used to. anyone have a 3.0?
| All times are GMT -5. The time now is 07:52 AM. |
