-   -   Custom Booster EASY 2 DO!!!! (http://tinyrc.com/forums/showthread.php?t=6541)
scottyboyfun 01-11-2003 06:45 PM
I thought of an idea 2 make ur own clone booster.
Get 2 pcbs of different frequencies, wire them up on 1 bit, put a few resistors on one of the pcbs forward and backward wires,
Integrate the 2 controllers into 1, and
Walah!
1 clone booster!
Or u could do this and create ur own Wild Char G, u'd have the steering coils un-used,u cold connect a transistor and use this to run another motor!
Or u could forget the 2 speed,and have 1 motor as a winch, ne thing can b done w ur imagination.
doctor dole 01-11-2003 06:56 PM
that wouldn't be a booster.
1st speed - slower than stock
2nd speed-stock
What's the point of that?
it's suppsoed to be
1st spd-slower than stock
2nd spd-faster than stock
scottyboyfun 01-11-2003 06:58 PM
Well there is a mod where u run a negative wire from the cell to the motor, instead of from the pcb, which is sposed 2 make it faster, so do that on the boost pcb, and/or eliminate some resistors.
