-   -   Hey DKS.....Whats up with 220mah (http://tinyrc.com/forums/showthread.php?t=6300)
MicroKeg 01-06-2003 09:38 PM
Are these 220 mAh batteries that you have listed on your site for the MS and BCG? If so, how long do these bad boys run? I easily get 7-9 minutes by cycling my 50 mAh NiCd, once a week. Why can't they add more voltage to the battery, rather than extended run time. I will not risk destroying my car, for more speed, to small of an area, and too fragile of wires.
funkymonkey 01-07-2003 06:29 AM
See the Laymans guide to dual-cell if you want higher voltage without taking sharp spinning things to your chassis. This mod uses 40mah button cells.
Im thinking of dual-celling my clone with a couple of 60mAh button cells I robbed from an old motherboard.
Ive seen 210mAh batteries, found them at good price wholesale, so will prolly be buying a whole rack of them.
binaryterror 01-07-2003 06:37 AM
As 1/3AAA is not a regulated size, the 210mah posted here a while back is too long, so you need to cut the body apart. Plus it is still only 1.2 volts. A dual battery makes the voltage 2.4 and if you put 2 150mah batteries would come out with i think (old electronics #'s may be off) about 200mah.
funkymonkey 01-07-2003 06:47 AM
Thanks for the info mate, i better check the dimensions, would be annoyed to buy 50 of the things and find they didnt fit! :D
If you double up the batteries you dont get increased capacity though.
1 x 1.2V/50mAh = 1.2V with 50mAh
2 x 1.2V/50mAh = 2.4V with 50mAh
The voltage doubles, the capacity stays the same.
If you put the batteries in parralell, the voltage stays the same, and the capacity doubles.
DKS 01-08-2003 05:26 PM
Correct, higher mah cells are indeed longer. I would not recommend these for quick turbo upgrades, but more for some serious mods that some crazy peopl out there do. I have a 2 cell Wild Charg that uses these and I get about 5+ more minutes run time with these.
