help, i need a picture of controller curcuit wiring
oks hears the deal, i need a picture of the wiring of the controller, because i need to know where the antenna wire is wired to..
i added a telescopic anteana wire right in the middle of the controller, and just forgot to wire it back har har i havent used my Bit in a month, because i couldnt figure out where the damn wire goes, so i just let it for a while, because i was messing with my 1/32 now, i sort of want to bring my bit around like i used to, so i really need a good picture of where the darn antenna wire goes to.. thanks |
MTL,
Took my tomy controller apart just to make sure. Check out QFM. They've got a controller diagram you can download. The antenna on the diagram is directly to the left of (switch 1). (SW1 on the diagram) On your PCB, the antenna connection is at the opposite end of the solder connection of L3. Good Luck |
hmm...funny that i never saw that ever since i saw qfm back then, har har
pretty useful, although kind of hard to read....but it says its the diagram for the 49mhz controller, im gonna guess this is the same for all controllers yah? thanks alot |
Yup, it's the same......the only difference that I know of is the crystal.
| All times are GMT -5. The time now is 08:24 AM. |
