which way does battery go in
lol ok i know im an idiot, i poped out the lil green battery , im curious and pokin around in my lil ZZ and i took it out and forgot which way it goes in, holding it with the motor facing right and steering facing left , is positive on the bottom? or the negative on the bottom, thanks lol
with the moter to the left the neg is on the bottom by the gears
lol...motor on right steering,left negative is closest to you,and positive is away from you,,,lol,,,or just the opposite of what he said,,,lol,,,i just had to sorry
Ok, who you going to believe :eek: :confused: :D
Someone else jump in with an answer. |
If the motor is on the right then the negative end of the battery should be facing you, did you look at the wires that go to the battery
Red= posotive Black= Negative :D |
| All times are GMT -5. The time now is 09:50 AM. |
