-   -   CAT5 wire! (http://tinyrc.com/forums/showthread.php?t=4618)
Socca 12-09-2002 11:43 AM
CAT5 wire!
hey i just got some Category 5 wire, and i was wondering if there is any way for me to replace my current antenna with the CAT5 without soldering??? please help! Thanks
DarthRacer 12-09-2002 11:49 AM
You need to solder the wire.
First, unsolder the original antenna, then solder in the new one.
There is no clean way around it, unless you cut the original antenna and splice in the new one, but I would strongly recommend against it.
Socca 12-09-2002 11:53 AM
dang
lol, the last thing i wanna do is solder it. darn anyone wanna come down to maryland and help!?!? lol.. well.. anyone need any free CAT5 wire? i have somelol, about 6 feet..
Coolmanmj 12-09-2002 05:03 PM
if u are serious ill take it. thats to replace the original antena right? How much more range do u get? And is it about the same size in diameter?
DesertJedi 12-09-2002 07:06 PM
You could strip about 1/2 inch off your existing antenna wire about 1/2 inch above the pcb. Next strip off about 1/2 inch of Cat 5. Twist both ends together and then put some shrinkie tubing and shrink it to fit around your handy-work. Ghetto at best, but it can be done...
dohc 01-20-2003 12:30 PM
cat5 wires are the sheznit! i get about 50 ft of range which is alot better than 20 ft :D
