-   -   Jerky steering (http://tinyrc.com/forums/showthread.php?t=4311)
Tillek 12-04-2002 05:59 PM
Jerky steering
I recently got a clone r/c for a friend. It's got some insane 2.6 motor with enough torque that it sails across carpet like nothing. And it steers almost too sharply, litteraly on a dime. The only problem is that it jerks while your driving. It will drive straight for a bit, then jerk left or right.
Is there an easy solution to this? Would spring suspension fix the problem? Or do you need more weight in the front? :confused: :confused: I'm not sure. Any help would be most welcome.
Ovgron 12-04-2002 07:09 PM
it may just be really fast. If your steering is kinda loose, at a high speed it will jerk around.
TemjinNeo78 12-04-2002 08:27 PM
Spring suspension would help a lot. But one question for you, how do u jknow the engine is a 2.6.....? I know cloes have crazy torque but most of them dont list it...
Tillek 12-04-2002 08:45 PM
well, I ordered it from char-g.com. and they said it had a 2.6 in it. Also, it's faster than my 2.2 bit but not overly fast, so I'm making the assumption that it's a 2.6. ;) btw, don't buy from char-g.com unless you want to wait 20 or so days to get the bloody car.
I'll add some springs to it and see if that helps. Thanks!
