pcb swap help
I broke one of the small stering wires and thats not a big deal i wanted to swap the zip bcb for the micro,my question is can somone tell me the best way to connect the stering wires im not the greatest at sodering.If possible can you give me directions of sodering these small wires to the new pcb.
Soldering help!
I place a small bead of solder on the steering wire and a small bead on the pcb. Place the wire bead on top of the pcb bead and the beads will melt together really easy. I recommend a 15watt iron ONLY! Higher watt iron can really make a mess of things when trying to mod these things.zznos
| All times are GMT -5. The time now is 11:18 AM. |
