-   Bit Char-G Parts and Hop-Ups (http://tinyrc.com/forums/forumdisplay.php?f=11)
-   -   3.0v Li-Ion cells (http://tinyrc.com/forums/showthread.php?t=3737)
microsizer 11-23-2002 04:01 PM
3.0v Li-Ion cells
hi im just wondering how good is the 3.0v Li-Ion cell, how much is and does it improve performence? where can i get one?
Chris 11-23-2002 08:54 PM
same question here, but I know for sure that it would improve performance if it is 3.0 volts to the motor. thats more than a dual cell mod with two NiMH or NicD batteries! hey, dual cell mod with two Li-Ion cells and a 3.8 motor. I think you would have to add 3 ounces of weight to the front to kepp it down! but, yeah, where can you get one of these?!
Ovgron 11-23-2002 09:22 PM
that would rule, dual li-ion cells with a 3.8 motor. You can but li-ion cells at online r/c airplane stores. Li-ion cells are used in micro airplanes (stick flyers, backyard flyers, slow flyers, etc) or airplanes that look like a balsa wind up plane.
Chris 11-23-2002 09:59 PM
would they fit in a bit witout modification? are they the same size as a NiMH or NiCD?
Chris 11-23-2002 10:04 PM
HERE YA GO!!:D bc3l I'm not sure of the dimensions of a bit battery though. HEY, ANYBODY KNOW THE DIMENSIONS OF A BIT-CHAR-G BATTERY IN MILLIMETERS??
oops, forgot to add the hyperlink:p http://www.maxxprod.com/mpi-7.htm
microsizer 11-23-2002 10:49 PM
so does any1 know the dimensions
tarnjit 11-24-2002 06:53 AM
around 16-14mm length and and 9-11mm width :)
Pojo 11-24-2002 11:01 AM
wow well i just put a 3v duracell in my car and it pops wheelies all the time :(
Coolmanmj 11-24-2002 08:31 PM
So will the li-ion bateries fit in the bit char-g's chassi? How much are they?
Pojo is that a regular battery you used (AAA, AA)?
And could u post pics of tour car?
Chris 11-24-2002 09:05 PM
where did you put the battery, though? if you mounted it on the back of the bit, the extra weight might make it wheelie. or did the battery fit right where a normal bit NiMH or NiCD would fit? how much did the battery cost?
tarnjit 11-25-2002 02:16 AM
i think u guyz misunderstood ..... he said he put a duracell in his bit ... they are not li-on cells... they arent rechargeable.
