ZZ/BCG Motors?
Can you fit a BCG motor into a zz?
Also what is the diff. in motor power(BCG, 2.2=ZZ, 2.2 |
yes and no
Yes you can easily fit a bit char-g motor in a zz but.....you will have to solder the resistors on your zz pcb board for the energy to bypass the pcb. the 2.6 is faster than NOS, 2.2 can be about is fast or slower than nos with the right gearing, 1.0 is way slow, the 3.0 is just extremely fast compared to NOS, and the 3.8 make the NOS look like a slug. I hope i was of assistance.
Thanks, Jeff |
nope
if you dont do the resistor mod then the 2.6 is the highest motor you can use on the zzs but it still lacks a bunch of torque compared to the NOS or turbo motor
just wondering how to u solder the resistors?
When I put my Microsizer b22 motor in it doesn't make good contact with the side plate on the car.:confused:
bend it
try to bending the plate in a little bit then.....
| All times are GMT -5. The time now is 08:19 PM. |
