steering busted
hey guys, my steering won't go back to the center, it stays left/right ........help
Sounds like a steering spring problem.
Check the steering spring to see if it is at the right place or if it is damaged. |
i checked that first, i took it apart and put it back together still no change...thanks for the reply
Did you check for debris that might have wrapped around the steer knuckles? There's gotta be somethin' there preventing the steer assembly from re-centering.
I figured out why, I just bought the suspension arms and they are too stiff and they press down on the knuckles and prevent the steering to go back to the center...........
| All times are GMT -5. The time now is 04:14 AM. |
