-   -   Problems/ Stabilizers and QFM springs (http://tinyrc.com/forums/showthread.php?t=2745)
Zakkorn 10-31-2002 05:12 AM
Yesterday I received a pack from QFM that had motors, batteries, gear sets, springs and other bits stuff.
So I said its time for me tor try the new stabilizers.
When I put a stabilizer (either the one with the 4 holes or the other) my bit goes to the left instead of going straight.
Does anyone knows why that happened?
And the other problem is when I tried the springs from QFM the result was that the magnet and the magnet's spring tension weren't enough for the Bit steering.
Do I need stronger magnets (rare earth) and stronger magnet's spring (?) or should I short the suspension springs a little?
-Thanks
Barry 10-31-2002 09:08 AM
You have to cut the springs as they are to long and put to much tension on the steering... Cut little by little until the car turns correctly.
Zakkorn 10-31-2002 09:28 AM
Yes, you are right.
I did that just a while a go and its better.
Also by having that problem I found that one of the two front wheels its about half mm higher than the other.
So probably thats the explanation of why it went left.
Thanks
