-   Digi Q (http://tinyrc.com/forums/forumdisplay.php?f=19)
-   -   Unintentional donuts (http://tinyrc.com/forums/showthread.php?t=254)
mcfitch 07-12-2002 05:14 PM
Hey all,
I'm having alitle trouble with the steering on my Digi-Q. If I set the steering trim to centered and try to drive the car foreward it turns left. I then turned the steering trim further to the right setting, and then all the way right. At this setting it will still turn left when attempting to drive straight, but not as much. Still, i can't get it to go straight. I've only run through 3 charges so far and it gets worse every time. Any ideas?
Thanks,
mcfitch
ViperKid 07-12-2002 10:02 PM
dude, what's this doing in the gallery? how bout puttin it where it goes. thanks
tinyrc 07-13-2002 01:23 AM
Good call; done!
mcfitch 07-13-2002 10:31 AM
Ooops! I don't know how the hell That ended up in the gallery section.
Anyway, I fixed my donut problem. I just took it apart and cleaned out the gobs of cat hair wrapped around the rear axel. Before I did the right rear wheel would barely turn.
-mcfitch
tinyrc 07-13-2002 12:56 PM
Cool, glad to hear it!
The Thunderer 07-13-2002 01:23 PM
One of the habits I've gotten into after using ANY of the cars I have is "clean-up". This is when I reshine the body, freshen the tires, clean off the axels (CAT HAIR/human hair, grass, thread, etc), clean up the motor and lube as necessary, check for broken parts/missing parts, and then charge batteries. Its my list. That way, its out of the way next time I want to race the cars!
ViperKid 07-13-2002 02:42 PM
you charge your batteries after you get done driving? doesn't that effect the "memory" of the battery or something?
The Thunderer 07-13-2002 09:57 PM
OOPs! I meant to say that I charge my NIMH's (not bits or Nicads), so that I can just "top them off" when I want to race the car. There's no memory probs with Nimh's. My error on the previous post.
ViperKid 07-14-2002 11:35 AM
it's all good;)
