-   -   Newbie, Good Choice on Mods? (http://tinyrc.com/forums/showthread.php?t=2488)
BlueBlaster01 10-25-2002 09:36 PM
Hi, I'm just getting into the mini rc's. (friend had one, so I have to get one! and it needs to smoke his) I'm getting a Microsizer Nissan Skyline GT-R (coolest looking body style IMO).
I want to order all this stuff at once, so are these good choices?
Dual 150mAh NiMH batteries
3.2 Motor
Cat 5 Antenna
Tire Set
Gear Set
Also, the Microsizer is going to have a crip cap right?
I plan on charging the dual battery set up via a 3AA 4.5 volt battery charger. How long would this take to charge the dual battery (150 mAh) set up. Thanks!
tifosi_ms1 10-25-2002 09:51 PM
If you are going to go all out get a Bit Char G instead of a Micro. They are pretty much the same price if not cheaper. Infact I got the exact same bit as you want for only $32 after shipping. There is more documentation on the bit so it will be easier to mod then the Micro which in some cases has been reported as differeing from the Bit.
BlueBlaster01 10-25-2002 10:24 PM
I thought they were exactly the same? Just name/frequency change for sale in the US ???
DriveWRX 10-25-2002 10:56 PM
BlueBlaster01, you are correct... exactly the same.
In fact, Tower Hobbies' new catalog, Tower Talk, states that fact.
"The Original micros made by Tomy!" :D
DriveWRX 10-25-2002 11:09 PM
Oops...
I forgot....
I have one OEM modded with dual 150mAh NiMH batteries.
It's handful to drive! :(
It's got:
2.2 motor
9.86:1 gearing
soft tires on all four corners (tires are from a real Bit not the tire set)
Here's a link that could help driving-wise:
http://tinyrc.com/forums/showthread....&threadid=2217
I charge mine using a plug-in charger that I made. 4.5V/800mA for 3 minutes.
I'm still working out the best length of time for optimum charge, though...
BlueBlaster01 10-25-2002 11:23 PM
How hard is it to make a plug-in charger? What are the part numbers for the materials needed? Do you think the 3AA 4.5 volt charger battery set up will provide sufficient power? to get a full charge.
DriveWRX 10-25-2002 11:59 PM
Plug-in Charger
Here's a link for the plug-in:
http://tinyrc.com/forums/showthread....&threadid=1727
Follow Namuna's link. It has Radio Shack part #'s, pictures and diagrams.
Here's a link with more useful info:
http://tinyrc.com/forums/showthread....&threadid=1547
BlueBlaster01 10-26-2002 12:52 AM
Thanks, I think I'm just going to make a stand alone charger...:)
RebellionInc 11-26-2002 04:14 AM
Hello peeps! i was wondering if i could use a 4 cell "C" size batteries to recharge my dual 150 mah or dual stock 50 battery mod? any suggestions? i need some expert advice. thank ya:)
