-   Kyosho dNaNo (http://tinyrc.com/forums/forumdisplay.php?f=158)
-   -   Same transmitter for dNano and Mini-Z? (http://tinyrc.com/forums/showthread.php?t=24501)
dNano_NL 03-01-2010 04:01 AM
Hi,
I have a dNano, is it possible to use the transmitter I have (Perfex KT-18 ASF 2.4 GHZ) for a mini-z as well?
If so, do I need to link the transmitter and car everytime I swap from dNano to mini-z?
Thanks!
Sinister_Y 03-01-2010 08:47 AM
Yes, you can use the same tx.
Yes, you need pair it everytime you change what car you want to run.
MrNanoTrax 03-01-2010 09:29 AM
yes... u can use a Perfex KT-18 Transmitter with a 2.4GhZ Mini-Z but no, you do NOT have to pair it every time you go from dnano to mini-z. you'll probably have to modify the settings (probably just the trim) for use with whichever model you choose to run at the time.
when pairing a transmitter to a model, that pairing is permanent until the car is paired with a new transmitter. a perfex KT-18 transmitter (and any other 2.4GhZ transmitter) can be paired to any number of models with a corresponding 2.4GhZ receiver, you just wouldn't want to turn those cars on at the same time ;)
Sinister_Y 03-02-2010 10:44 AM
I stand corrected on the pairing. That's good as I've been pairing each car in turn everytime I change it. Thanks Q'on.
MrNanoTrax 03-02-2010 11:55 AM
no problem bro... we all learn something new every day :D
