Epoch to 1/32 conversion
1 Attachment(s)
1/32 Mustang Slotcar converted to R/C with Epoch chasse, hubs and Laser cut mounting plate
1 Attachment(s)
1/32 Camero slotcar converted to R/C using the Spec-2
Spec-2 to 1/32 conversion
1 Attachment(s)
Here is another view of the Camero showing the Shotgun motor mount and two Epoch motor mounts glued together to get the axle to axle right, this is the one with Mini-Lit Dif and hubs using Mini-Lit bearings.
thank you for sharing!
couple quick comments... 1. this is an epoch, not dnano, belongs in the epoch subforum 2. please don't post 3 seperate threads for the same topic. simply reply to your initial post :) did you do make the laser cut plate? |
if your having trouble putting images in a single reply, simply post one, and put the rest in sequential replies. if that is not working, do what you have to and simply include in your post that you wish them to be combined as i had done for you :)
Welcome to the forums.What type of input does the laser cutter take. I may have to look into adapting some other slot cars into rc. Great work.
good question. i can model to several file outputs, which are compatible for you?
have you done any chassis upgrades to the epoch that make it a direct fit for slot car bodies?
also, the cheap muscle time rc bodies are a good line of vintage muscle cars to scavange from. |
HI there, I'd like to chime in. Even though both are 1/43 scale, aren't the Epoch's still bigger, "thicker" than the Dnano and more likely to fit these 1/32 scale bodies?
| All times are GMT -5. The time now is 06:31 PM. |
