Buying my 1st Dnano
Hello all, I have decided to buy my first Dnano. but before i do, there are a few things I need clarified.
Are the instructions in english ? Are you able to drive more than 1 car with a single controller? not at the same time obviously. Last but not least, how long is the run time and charge time? Cheers |
any company that puts out any product without english is asking for failure... thats a no-brainer. 2, yes... the radio is 2.4gHz & is used exactly as a DSM transmitter/receiver would work... except the dnano's receiver is already built in (in short, u can bond ONE transmitter to as many models as you can afford). 3, run time is normally 15-25 minutes and charge time is less than 10 mins.
srsly charge time is less than 10min? the ppl in the kyosho shop in hong kong saids tht charge for 30 mintues and it will run for 30 minutes?
i don't know what they're using but using the stock charger & stock battery that come in the starter kit, you'll get charge/run times as i've quoted above.
Obviously the runtime depends on how hard you are on the throttle, and the charge time depends on how depleted the battery was, but I would say my estimates are closer to Nanotrax's than the guys at the dNaNo shop in HK.
thx for the information!
Is there a built in low voltage cutoff in these or do you just have to be careful on your runtime?
Someone said there isn't a LVC on dNano. I am not sure.
The car slows down abruptly, significantly.= time to charge. |
| All times are GMT -5. The time now is 03:12 AM. |
