Shocks Atomic vs Hot Racing
http://lbspd.com/v-web/gallery/album...9/MVC_462L.jpg
Atomic (orange) Pro’s Comes with grease. Finer threads for more precise spring compression adjustment. Larger diameter shaft with narrower head and a tighter/better fit in grease friction tube. Narrower profile. Fits available smaller diameter springs, i.e. the stock springs or the easy to find red Xmod truck spring shown in the photo. Con’s Does not come with springs. Higher price. Hot Racing (blue) Pro’s Comes with two sets of springs. Less Expensive. Con’s Does not fit readially available heavier springs, i.e. Xmods truck springs. Coarse spring compression threads. Does not come with grease, and likely not intended for it. Loose narrow diameter shaft. http://lbspd.com/v-web/gallery/album...ssasembled.jpg Results Appearance, finish, and overall bling factor is about even. Value goes to atomic, since with a little shopping you can find them for under $20 (19.70 at TinyRC.com) instead of their outrageous manufacture suggested retail price. Function goes to Atomic, but it should be noted that the stock shocks modified with the right size O-ring or piece of wire insulation and grease, the right springs, and a compression spacer, if needed, will yield indistinguishable results for a fraction of the price. Feelings Since I’ve used Hot Racings shocks in larger cars I felt let down and even a little cheated by these, especially when I consider the fake piggy back’s they are also offering. Even though they where quick to come out with aftermarket parts it seems that performance is not one of their primary concerns. I applaud the fact that the HR shocks comes with two sets of springs but unfortunately the stiffer of the two (blue) are roughly even with the stock springs, the lighter red pair are way to soft, and to make it worse the diameter of the shock is such that neither the stock or popular Xmod truck springs will fit. And although the shocks will work with grease they do not appear to have been made with it in mind, the shaft is very loose and aside from the spring adjustment nut are nearly identical to the stock shocks in terms of function. I have no doubt that I’ll be able to modify them just like a set of stock springs but the fact remains that I shouldn’t have to, my overall feeling is that performance was not one of Hot Racings priorities. Compared to the Atomic shocks that even through they do not come with springs are at least narrow enough to fit the available heavier and/or lighter Xmod truck spring options as well as the stock springs. The snug fitting shaft and piston hole where clearly made to work with the provided grease so that if not “Oil” shocks as advertised they at least are a well made set of grease shocks. I guess it makes since if you think about it, Hot Racing at this early stage probably has trouble envisioning the Micro-T as anything other than a cute little toy in need of hop-ups to make it “look like” it’s grown up brothers. Atomic on the other hand with their involvement in 1/28 scale Mini-Z racing has a large customer base already racing similar size cars who would expect, if not demand, parts geared toward improving performance not just looks. |
good thread
great info thanks
the blue one looks like its bent like a bitch ?
Great write-up!
I have Atomic shocks on all my micros and love them. I also like the fact that the body of the shock is silver, which hides any scratches. :cool: |
| All times are GMT -5. The time now is 12:22 PM. |
