-   ZipZaps Monster Truck (http://tinyrc.com/forums/forumdisplay.php?f=135)
-   -   Took zzmt apart, how do i put it together again? (http://tinyrc.com/forums/showthread.php?t=22974)
Realuser 12-30-2006 07:16 PM
Hi, im new here.
Refer to my thread:http://www.tinyrc.com/forums/showthread.php?t=22973
I took my zip zap mt apart(didnt disconnet any wires) and now i cant figure out how to put it back together. It fell apart before i saw how it WAS put together....
Is there a guide that can help me? This sucks :(
(its the very bottom part, the drive components)
UPDATE: I finally figured out how to put it back together, but im having trouble keeping the battery from interfering with the little white gear that moves left to right to turn the wheels. What should i do?
UPDATE TWO: I figured out how to keep the battery away, but now the steering isnt springing back in the striaght form, and sometimes gets stuck and wont swich directions. what should i do? I made sure the pin was between the little metal spring thing.
Jazz32 12-30-2006 07:52 PM
I would again make sure that the steering gear is placed between the legs of the steering spring. It might have slipped out or something. You can take out the steering motor and the two screws holding that one piece on rather than taking apart the bottom.
Realuser 12-30-2006 08:02 PM
Okay i will do that, it is also having very bad turning problems and it sounds liek the gears are skipping very bad. :(
Jazz32 12-31-2006 01:15 AM
One of the gears is probably out of place or something isn't tightened down properly. Make sure that the turning motor is all the way down as well.
Realuser 12-31-2006 03:27 AM
Okay i got it a while back. Not sure what the prblem was but it is fixed. Now to another problem, IT NEVER ENDS!
My battery seems to be pooping out. Im getting much less time to run it after a charge and its going slower and has less torque. Suggestions?
Jazz32 12-31-2006 03:29 PM
Put new batteries in the controller or charge it for more than one cycle.
