Lithium Battery Montior
Who here can help me with this schematic?
http://img65.imageshack.us/my.php?image=monitorsi8.gif |
What help do you need? Your part numbers are there and is straight forward. A simple "help" will never get a response. You need to be as detailed as possible.
Just with puting it together.
You've got part numbers, a diode, and the traces are all straight forward. just looks like you need to find those parts, whatever type connector you want to use to attach it, a board, and solder it up.
You need to be more specific on how you want help. |
help with finding the parts a bord and how to put it together.
I am not a master in this type of stuff but let me see if I cna help you out.
Here is a link I found to match te type of "Supervisor" you need. This is the part that does the work. LM810M3-3.08 http://www.national.com/pf/LM/LM810.html Next you will need this part: Which a google search reveals it is a red LED. L517URD-F Seems to be fairly simple up front. From the photo you provided you would wire it up like so.
Hope this helps. :cool: |
| All times are GMT -5. The time now is 10:56 PM. |
