centering servo
for some reason my zip zap wouldnt go straight even after adjusting the alignments no improvement is there a better way of going straight :rolleyes:
What kind of adjustments did you do to the car? How did you re-aline it? I'm not so sure it's alligned yet.
I use the alignment on the bottem of the car its a se version
If you pick up your car, and look from the bottom at the tires, are they straight? If not you need to re center them. If they are straight, you might have a hair cought in one of the tires and it's causing friction on that wheel and not letting it spin, so your car will be pulled to one side. Check for that also.
hey hotmod252
i have the same problems with the zzse. i use the underbody alignment. i just recently figured out that 1 or 2 of my wheels is off alignment. |
hey hotmod252
| All times are GMT -5. The time now is 09:31 PM. |
