Steering Knuckle Trimming
So I was visiting AtomicMods.com, and wanted to try there Steering Knuckle Trimming. But they had a warning about cracking the knuckle, so I find a easier way, and it takes 5 minutes to do it.
The concept is found on this page: http://www.atomicmods.com/How_To/XMO...e_Trimming.htm Do not use anything else shown on the page. Here's what you want to use: - Stone drill bit(to sand down the plastic) - Drill(to operate the above item) That's it... no need to use pliers and stuff.. the stone drill bit costs like 2-3$.. and you might even have one at home already! ;) |
i used a dremel the cutting wheel attachment. it only took me about 3 minutes. :p
i did mine with finger nail clippers :P
This looks like that would not help you turn tighter or faster, and that would void the warante/ get you kicked out of teh XRL. personally i would not do it unless you don't give a _____ about the XRL, or have extra knuckles such as from the AWD kit.
| All times are GMT -5. The time now is 07:33 AM. |
